Edge is a joint research team between the University of Bordeaux and Inria.
Our research interests lie in the field of operations research (O.R.) and integer programming.
Our goal is to propose mathematical methods and algorithms for abstract models that can be specialized to address a large number of problems.
Our main methodological tools are based on decomposition methods and so-called extended integer programming formulations.
Our expected contributions go from theoretical studies of problems and abstract models to algorithms and their efficient implementation in decision-support tools.
To maximize our impact, we develop high-level interfaces for our methods, so they can be used by O.R. practitioners and decision makers.
